6 volt air/fuel ratio kit
50Trucking
Has anyone heard of or can tell me where to find a 6 volt air/fuel sensor kit?
Would need a 6 volt 02 sensor and guage.
If not is there a way to monitor air/fuel ratio without this setup?
buy a converter off amazon —5-11 volt to 12 volt— that would also isolate the sensor from the dirty 6v generator system
Read your spark plugs. The color of the tips should be a light gray or tan after a trip indicating your Model A driving technique using the GAV is good, and your engine is healthy.
Look on the v8 side of the site,
The answer is to use a small lithium batter to power the O2 sensor or a 6 to 12 converter
Lawrie
