Daves55Sedan
I have long considered installing an electric fuel pump and had my eye on Airtex E8902, 6-V, 2-4 lbs output pressure. Last time I saw them listed in any of the repro parts suppliers they were fairly reasonable and seemed to be a popular item.
WELL...now they seem to have disappeared from all the suppliers including chain auto parts stores.
If this keeps up, I am going to wear out the oil-bath air-cleaner clamp on my '55 Ford.
Wanted to use it as a priming pump only and keep the mechanical pump, although it may be nearly flooding the carb as it is, since it is putting out 4-1/2 lbs pressure before the carb. Whenever the car goes uphill, or if I make a quick stop in reverse, the engine wants to die immediately unless I take it out of gear real quick and step on the gas. Very frustrating.
Fuel pressure regulators are out of the question. Been there done that over and over.
Solution for electric pump? Solution for overpressure at mechanical pump that doesn't include running a whole bypass line back to the tank?
