Hi Jeff, I went with a 12 volt system and use an alternator, you've indicated the guy you got it from has it running on a 12V. I like the 12V set-up ( some people do some don't ) and there are kits to convert the gauges to run on 12V and they are cheap. Basically just inline resistors to reduce the 12V back to 6V where required. Your starter will work fine on 12V as it is heavy duty ( many of us do and it works fine ) and spins twice as fast as with the 6V, a big advantage for quick starts. The stock 6V wiring is more than adequate for the 12V so any new stock harnesses you buy will work fine.
Here are some of the things you have to worry about if he didn't set it up right when he converted to 12V. All the lights will be 6V and burned out. You need to go 12V on all the lights, ( I think the 12V lights are brighter ). You will probably have to put a resistor ( should be in the 6V to 12V conversion kit ) on your heater motor to reduce the 12V to 6V as it's not as heavy duty as the starter motor. Your amp gauge can run on the 12V as it is only measuring Amps. Temp., fuel, and any other gauges which have electric sending units if used with the 12V are already fried and will need to be replaced.
Working on them is half the fun so enjoy the trip.
