Habusailor,
Depending on what you're working on this added info may be helpful...
Most electrical parts were changed from 6v '+' ground to 12v '-' ground for '56.
There was another change to the Dash Gauge circuit from '56 to '57.
'56 gauges were built for a full 12 volts, '57+ gauges use 12v power, but there is a voltage reducer/regulator in-line before the gauges. (two example photos below) .
