would the 6 blade plastic fan be more balanced than the 2 blade aluminum stock fan? not necessarily is the only benefit more cooling? the model a times did a test of the various fan blades on the model a, measuring the air flow at given engine rpm and several locations, in front behind and by the middle engine area. The 6 bladed fan did not win.
Use PLASTIC fans for safety, did you ever try to put your elbow against the back side of a METAL fan? PLASTIC fan jist goes, "BRRRRP!! YES, I'VE DONE IT!!
Bill W.
What would our world be like without PLASTIC?
Bill W.
Bill W.
Tom,A lot less road litter.![]()
Tom,
If you cleaning the roadside, DON'T touch them corked up gallon jugs of some UNKNOWN YELLOW LIQUID, them dudes will BLOW UP, from sittin' in the HOT SUN!!!!!!The fumes would probably power a Model A!
Bill W.
