Ray,I do not know what year your working with,but if it is stock 33 thur 36, and you want a 6 blade fan, only the 15 1/2" fan blade will replace your 4 blade fan. The other two 6 blade fans that Kurt mentioned will hit your upper radiator hoses. I do agree with G.M.about the shroud,only there is not a lot of room on 33 thur 36 to add a shroud.I run a 6 blade fan on my 34,I have not noticed any more noise than the 4 blade fan.I also have original engine pans,so the air thur the radiator is force at the engine,and out the hood louvers.My engine block was boiled out,the radiator was cleaned,I installed Skips pumps,and Bobs thermostats.I put 1900 miles on this 34,running at 178 degrees.Now this car runs so cool,I am thinking about wearing my longjohns next summer,when I am driving it. I hope this helps.E.P.Williams
