6 blade fan
edscoupe
Hi i have a 48 ford coupe 59ab motor, during the summer construction here in minn traffic is some times at a stand still, and with parades i have a cooling problem. I look at a scotts 6 volt fan, but conserned about air flow when fan is not needed. I would rathere us a 6 blade fan and a shroud with the over flow perssure valve. What i need is what 6 blade fan are people using on there 48 ford car and is there a shroud the will fit. Thanks Ed
If you can find a shroud & 6 blade fan from a 42-47 V/8 pickup I think it might just be the ticket. others will know more than me.
Coupe,
Walker makes a killer shroud out of heavy black plastic. You will
have to cut the fan clearance hole in it but it's worth it.
Flat Jack recommended it to me a while back in lieu of a 6v
fan.....glad he did!
Charlie ny
