59AB swap into a 33
dean333
What would be required to swap a 59AB engine into a stock 33? Thanks
In addition to the adapters Duece lover mentioned, I had to add a small spacer (3/4” I think) on top of the adapters to lift my engine up to allow me to remove and replace fan belt.
And that reminds me that you may need a crankshaft pulley with single seave (I cut off outer seave on mine to clear crossmember).
This also means you’ll need to run a generator mounted mechanical fan.
Just did it ; and had to buy a Red's header for the left side. Otherwise the advice is spot on, Steering box should be installed first also. Newc
The early Toyota steering box can be used for header clearance. I used one rim a 77 Toyota, I think, that waz along time ago,
Gramps
I have a 59a in my 33.
here's what I did
Used those horse shoe bits on the front engine mount, plus a small space ,I think 1/2 inch.
used a turned down twin pulley,( cut the outer one off)
turned down the crankshaft pulley bolt ,( turned the crank start dogs off)
cut the front of the scatt crankshaft off to suit single pulley
used my stock 33 manifold, carb and generator.and fuel pump
used the 59a water pumps.
Used my stock 33 distributor ,But fitted an 11A advance.
used the hose kit from B/drakes.
Used the stock 33 exhaust manifolds
Nothing else needed changing
It has been in for years,
Lawrie
Lawrie: Thanks for posting that info. If possible, please post close up and long shot photos
of what you explained in your post. Thank you. Jim
Will get some pics today,
Im not supposed to be in my shed ,as I had a small hiccup yesterday, 6 stitches in my hand,
Lawrie
some pics, also on the front of my spare 59A engine for the 33
Let me know if you want specific photos.
I apologise for the dirty engine bay,My 33 does lots of miles.
Lawrie
Pay attention to what Lawrie covered - is exactly what I did in my original 34 Ford. One thing to note is that he mentioned the 11A advance mechanism in the original distributor. If you're going to run the original distributor, this is really a smart way to go - the advance curve is much better than the original one.
Another option is to run a later 42' style 'crab distributor' (and 2 bolt timing cover) that already has the better advance mechanism. While the crab style distributor looks different than the original 'diver's helmet' style distributor, it is also a heck of a lot easier to work on.
No matter what distributor you decide to run, have it gone through and setup by somebody who rebuilds them and runs them up on a distributor machine. Charlie NY or Michael at ThirdGen are two of the guys that I would use.
