59Ab running flat head motor
fordy46
Kent
Ohio
Price
1,400.00
I have a good running 59ab motor that is presently mounted in a test stand. It shows 40lbs oil press. cold and when warmed up 20 to 25 lbs. at a reved state. No water leaks or cracked block. At some point in time it has been rebuild because it is bored to 3.250 dia or .060 oversize. It is in NE Oh. and offered as pick up only, come and see it and hear it run. Includes all you see in the picture except, radiator, exhaust manifolds, and radiator water tubes. $1400.00 Also have a nice side shift ****** for 41 thr 48. Turns freely and shifts thru all the gears. $200.00 Also 41 thr 48 complete rear end less backing plates 4:11 gears $200.
