Need help all. No spark on stock 59ab with crab distributor....
Both coil windings show correct resistance. Distributor tests fine on the bench (both points gapped at .015, cleaned, and ground to the housing when closed and are not grounded when open). When I 'bypass' the rotor and cap and go straight from the high tension wire to a plug wire, I get spark. But when I plug the high tension wire into the cap, nothing. I cleaned the rotor and cap terminals, but still nothing.
I don't know what else to do other than to replace the cap and rotor. But they look fine. Before I start throwing parts at it, any ideas?
Thanks,
Ron
Thanks,
Ron
