59AB manifold vacuum banjo thread?
ajmac
Hi All,
Could someone tell me the UNF thread in the inlet manifold for the banjo bolt that connects the distributor vacuum pipe to the manifold please. It’s bigger than 1/4” if I recall. I am away from the engine and want to buy an adaptor to fit a vacuum gauge for testing.
If you are referring to the small connections along the edge of the manifold between two adjacent ports, they are 3/8" UNF. They take a specific oliveless tapered nut.
Mart.
Here. 1/2 inch wrench size.The one on the right was rounded so filed it to work with a 7/16" wrench
Is this the one you are looking for? On my 59AB there is a "silencer", not a banjo bolt that the vacuum line for the wipers connects to.
I'm going to jump on this thread and ask petehoovie if he knows where to get this fitting. Mine cracked in half (porosity in the casting...) and I can't find a replacement. Otherwise I'll have to weld something together with a banjo bolt.
