Ed Pitts
If you are going to put a 59AB engine in a 36, here is the hose combo that fits. Upper: Gates 21253
Lower: Gates 20151
If you are going to run an alternator, here is the belt to use with the fan mounted alternator: NAPA 22545
The 46-48 fan will not work because of the radiator tilt.
Use a 3 wire alternator because of the pulley size to mount the fan. It starts charging as soon as you come off idle.
This combination worked for me. Ed
Lower: Gates 20151
