so heres how it went at my house. i post this because i spend a lot of time searching old posts for answers to my questions, and usually the folks here that have been at it way longer than me always have the solutions, thanks for that, and now i hope i can sort of sum up all the old posts with some facts...well, or at least what my tape measure said. here goes- i have been hoarding a set of what i thought was the correct, real ford adapter brackets to mount the newer motors in the older cars. they came to me in a 47 or so big truck that had a 8ba merc motor installed. they are the things with the funny angles in the photo. this project is as the title stated, 59 block in a 34, and i thought i was so cool to have the real ford part. i didnt notice until it was time to set the motor down that the studs that go thru the water pump are 5/8. standard mount bolts are 7/16, the holes in the pump are quite sloppy and would take a 1/2", but not 5/8 without some butchering. too late for butchering when the motor is hanging near ground zero, and i didnt want to wreck the pump cores. i now know those brackets are for 49 mercs and will work if you are using an 8ba block. i had always thought the 8ba with truck pumps puts you on the same plane as a 24stud pump motor mount, but not true? so now with motor hanging i need new adapters. the merc mounts were 1 7/8" tall. still thinking pump heights were the same i made some new U shaped things, and with the aid of my poor mans iron worker (the thing with two 1" shafts welded near each other in the photo) i made them exactly 1 7/8, and perfectly parallel, my mother would be so proud, and then set the motor down to see how much the offset is for the hole location. notice in the photo i have one of the merc mounts set on its side, if you look close you can see that the hole for the bottom rubber mount is centered, and the stud is about 1/2" wider, and about 1/4" toward the front of the car. on a side note, i had seen these adapters on ebay for about 50 bucks. link http://www.ebay.com/itm/371822156037?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT more on that later. so i set the motor down on my new perfect mounts to scribe the offset for the top holes to find that the water pump outlets were lower than the front frame cross member, note the scraper on the right in the photo slid under the pump outlet. so i then made some 3/8 thick washers with a hole saw, see second photo with scraper on left, and just barely had room for the hose to be put on and not rub on the frame. at this point i thought i was done, the crank shaft nut is close to where the crank guide should be (the previous owner thought that part was not needed). the fan seems to be parallel to the radiator, but the radiator outlets are about a 1/2 higher than the frame, and my pump outlets are near the frame. the hoses will give some, but really i think the motor should come up some more. so heres the moral of the story, the merc mounts- 1 7/8. my mounts with spacers-2 1/4, and should go up another 1/4 i think. the mounts on ebay are listed as being for 32 to 36 cars, which as recently discussed are not needed for 35-36, and the seller states they are only 1 1/2" tall, and they have the holes inline, not offset as the should be. not trying to put the guy out of business, but they can not work. more searching showed me an old post here by jseary, always in the know, and it appears he welded a plate on to raise it up, and mart from over the pond, also one our great resources, made mounts of rectangle tube that appear to be higher than the 2 1/4 i am at, and more like the 2 1/2" i think it should be. so, i hope this summery will help the next guy who does a search, and i hope i have not crossed a line in mentioning folks by name, comments welcome as always, end of long ramble, thanks, skip
