Car starts fine....hard starting when hot.....just a few minutes after turning off. Crab distributor with points from Bubba using his supplied coil and balast. The coil is blue in color as the first one was purple and defective which was gladly replaced. The 2 holley 94s were done by charlie ny with blocked PV. When hot this car will not restart. I pull #5 plug wire , place screw driver into plug wire to check for spark and motor starts right up....did this twice on two separate occasions.
Running solid core wires and coil is mounted horizontally. Spark plug wires are run through individual stainless tubes which are not grounded. Going to ground these stainless tubes..... any chance the coil position is problematic ....or ????
