36cabrioletfrank
I'm a newbie rebuilding a 59ab for my 36 cabriolet. 3 5/6 bore and 4" stroke. Trying to follow Ol' Rons recommendations for a reliable street engine.
I'd like to keep the compression ratio near 8.5 to 1. Do I need to use aluminum heads with a 74cc chamber volume?
I have an 8ba offy intake with a 4bbl holley. Can I use it on my 59ab? What mods do I have to make to the road breather system? Need to use an electric fuel pump right? Do I have to use a pcv valve or can I just block the road breather port on my 8ba intake? Do I plug the 8ba oil fill on my manifold? Do I use the fuel pump mount as an oil fill with a breather? Do I have to block off the fuel pump push rod bushing? Should I just spend $399 for an offy intake designed for the 59ab instead?
Planning to use a rebuilt 10" clutch from FT Wayne Clutch and a 39 ****** with lincoln gears
Please lend me your thoughts and advice
Planning to use a 39 ****** with lincoln gears.
