Prawbly
Hello all
I bought a 36 tudor with a 59AB. It has the Helmet dist. in it. The person used an early cam with a pressed on gear. I'm replacing the cam with the correct one that uses a bolt on gear. I ordered an aluminum gear and the extension button for the early dist. My question here is will I have to change the timing cover, or will the early one that was on it work okay ?
Would like to know while I have it apart. Thanks Pat
