I had a little time to work on it tonight, I could get the bolts out if I cut a half moon over by the starter side on the pan, there's plenty of room there. It would not affect the structural integrity of that area. I'm not confident that the PP would come out without dropping the pan. I pulled the transmission because it was a bit noisy and the clutch was dragging , upon inspection the clutch & pressure plate appear rather new, clean no noticeable build up of any sort. The clutch was dragging perhaps because the release arm bushing was worn out even though the clutch was adjusted very high about 3/4" free play, it was still dragging. The shaft bushings are tight and the joint on the bell housing is fine. I thought perhaps the pilot bearing was bad but from feel and sight it's fine and has no unusual amount of play. Thinking I may finish rebuilding the transmission, install it with a new bushing on the shaft, properly adjust the linkage and try it. It only takes a few hours to take the trany out, or reinstall it. I would rather not pull the engine just now, that's a better project for winter. If I only knew that the pp would come out with the pan on. At this point my main question would be can the pp be removed with the pan in place? I would get the bolts out.
