OHV DeLuxe
Any info on an oil pump out of a 59a i'm building?
Casting numbers are W pre-fix.
Unlike the others i have, this body looks die cast alloy, cast iron end cover, cast iron elbow with die cast pick up bowl.
Dimentionally the same as any other 59a pumps.
No wear what so ever, factory spec backlash and tooth to housing clearance.
