pooch
Got reco engine running and it was OK for a bit...65 pounds oil pressure.
Then it suddenly is pouring oil out from behind flywheel.
Pulling engine today.
I misplaced the original grub screw at the end of oil gallery, and made up a grub screw to fit.
I have since found the original and it looks to be a bit tapered to seal better.
My grub screw was a piece of cut bolt so it was straight and although I put sealer on it , it must be the culprit.
I am guessing I will find the screw has leaked pressurised oil and blown the cover gasket out .
It was too sudden and too much oil for anything to do with the main rear seal I think.
What is the general consensus?
