59a Fuel pump push rod
No oil pressure problem unless there is a hole in the bushing.
"Oiling" needs further explanation?? The lack of a rod can cause oil to be thrown up toward the breather. This can cause "oiling" of the firewall especially if the stock baffle system is not being used. However, this does not mean there is an oiling issue with the internal engine components.
Both opinions have been expresse on this forum. My experience is with an 8ba and I am not sure I can accurately measure the difference but it appears to make a very small difference. Oiling is different from your engine and mine so listen to the other posters.
