Being new to flatheads, and starting off with one that wouldn't run, I'm happy to say I've put around 1500 miles on it this summer with the help of you guys. My only issue that I need to resolve now is even warmed up to operating temperature (at the 1/2 mark) the engine starts breaking up at around 1/2 throttle. For instance when I'm cruising and I give it about 2/3 throttle or I'm trying to climb a hill the engine runs extremely rough, to me it seems like an ignition issue, my guess would be the vacuum advance or lack there of is my problem. It runs good up to that point. I'm running a 59A, 6V + ground, single Holley 94, petronix pointless module and petronix coil, stock trans and rear end in a 48 2dr sedan. I think my timing is about maxed out, as the screw is just about at the bottom of the opening, it seemed to run best at that setting, and doesn't ping. I'll also say I can cruise at 45mph for about a long time and my temperature stays at about 5/8 on the temp gauge, but if I go up to 50mph the temp goes to 3/4, not sure if that's a completely different cooling issue or timing related.
