The answer is NO. the bolts are made part of the rod, if the bolt is broken or the threads are bad you have to replace the rod. WaltOkay, but let's say one needed to replace some BROKEN rod bolts on that engine: my original question is: is it Possible? Thanks!
Hi everyone, I have a 1947 59AB 239 V8 engine with the original, old rod bolts/studs that should be replaced; but how do they come out of the rod? And if they do, where can I buy new ones? I greatly appreciate any info, thanks! John
