justanotherguy
Hello Everyone,
I've learned a lot snooping around here. Great info you are all sharing. Thanks. This is my first time asking a question. Maybe someone can point me in the right direction.
I'm trying to remove stock heads on a "running" 59A-B. After a couple of days soaking the head nuts in Kroil, they came off without anything breaking. Then I managed to loosen the heads slightly from the block. On one side I can easily slide a putty knife all the way around the head, On the other side I can do the same except there's even more of a separation... at least 1/16". But that's it. Neither side is wanting to move at all. I'm no Atlas, but they aren't even wiggling. I've been using Kroil on the studs. My first thought was that he studs are binding just slightly and enough to prevent the heads from moving any further out. Any thoughts? I'm open to suggestions.
More trivial info just for grins.
Compression is irregular with 3 cylinders at 10-30 psi and 5 others at 85-90. This engine has been in a running /driving car for years, and judging from what's left of a sticker on one of the heads, it was rebuilt in the 50's by Sears. I drove it into the garage to address this problem. It ran surprisingly well considering. I can see a couple of burnt valves by looking in the spark plug holes. It's not burning any blue smoke, but there's a hesitation every once in a while consistent with burnt valves. So, my thought was to possibly attend to the valves with the engine in the car. Thinking that the first step of removing the heads would be fairly easy. Yup... that's what I thought. I'm reluctant to remove the studs. Am I missing something obvious? It wouldn't be the first time.
