JSeery I believe it is balanced as I questioned the machine shop & Ft Wayne & both stated that their work is balanced. It is presently in the roadster now & working just great.
The ****** doesn't even slip out of 2nd . I think the ****** may not be original to the car tho as it does seem to go pretty good now but the little 21 stud is kinda having some oil burning problems in #5 & compression done a bit. I had this 59 engine so had the machine shop do its' thing. They just bored enough(.040) to clean the cylinders up. The pistons, valves,guides,Johnson adj tappets,melling oil pump & all the bearings are new. The cam has been ground to L-100 specs & parkerized. The block has been squared & line checked,was within specs. Hopefully I can get the dual 97 carbs tuned in.
Should be a good running sounding exhaust with twin porters.
