IMoveMetal
I’m putting together an engine with a 59 block from parts and have what looks like the “soup can” style oil pump. From what I can tell, it probably came off the 1934 engine that was originally in the car. It's in good shape and was thinking of using it.
The oil pan I have doesn’t seem to match up with this pump setup, baffle is in the way. I also have an oil pan baffle that appears to fit the pump but doesn’t fit in the pan.
Before I start hunting for more parts, is the move here to find a different pickup for this pump, or am I better off matching the pan to the pump setup instead?
