Walton Feep
Hello folks!
I have a lot to learn about my early Ford V8 so please excuse my novice questions.
I purchased a 1941 Super Deluxe over the summer. It is a solid enough car, complete and, after some extensive mechanical work, drivable. It has a replacement 59 A/B.
I had extensive work done to it at a local shop - new carb, entire fuel system was replaced including the pump and tank and a pressure regulator was installed. They rebuilt the brake system, did suspension work, and replaced plugs, wires, points, caps, rotor, capacitor and coil. It runs, shifts and stops well but for one issue. After a few minutes driving the engine seems to start "surging". It isn't effecting drivability and it will still idle fine at stops. But I am just not confident that this is "normal".
I am wondering if I am just holding it too long in 2nd gear as when I upshift it seems to be better. I have had no experience with a car like this before so I am not sure what is normal.
The temperature gauge indicates the cool side of "normal". I do intend on calling the shop that did the work about it next week.
Any ideas on a place to start? Temp? Timing? Fuel supply?
Thanks in advance!
Feep
Thanks in advance!
Feep
