The truck FE was first used in 63, 292 Y-block and 223 6 banger until then? 58/59 Fords had the 332 & 352, not sure when the 360 in trucks came around. My 73 F100 was bought new with the 360.
The Edsel was just a 332/352 board and stroked to separate it from the Ford line.
The two top models in 1958 used the 410 engine.
It was NOT 410 cubic inches, it 410 foot pounds of torque.
410 cubic inches 440 foot pounds of torque.which is why it had 440 on the rocker covers
Summit shows different pistons for these engines https://www.summitracing.com/search...rtOrder=Ascending&keyword=Ford FE 360 pistons And https://www.summitracing.com/search...size/5-9l-360/engine-family/ford-big-block-fe The pistons shown for the 361 Edsel at Egge Machine run $660 a set. Are the originals dished ?The Edsel 361 is the same engine as the Ford truck 360 FE. For some reason they called the Edsel a 361. I guess to have it's own identity.
Sal
Summit shows different pistons for these engines The pistons shown for the 361 Edsel at Egge Machine run $660 a set. Are the originals dished
The later 360 LT (1968-1976) engine was as a result of FORD being able to use the 390 block casting on both the 360 and 390 cutting costs over the previous 352.
They are both the same displacement but intended for different applications. So the piston style would be completely different. EGGE pistons are for the earlier 361.
Funny how that works out. The 360 Truck engine has a slightly larger bore, yet the Edsel has a one cubic inch larger displacement.
Sal
