Update: not so good. Sent the carb (a 1958 Ford 4100) off for a rebuild. Installed when it came back. Engine very hard to start and when finally did, it coughed, sputtered, backfired and then died. I tested the fuel pump by removing a line and watching the flow--looked good. Tested one spark plug and it fired ok once per revolution. Plug was slightly sooty, probably from over rich carb before the rebuild. Multimeter test on coil (Pertronix Flamethrower 3.0 ohm) showed 3.5 ohms between primary contacts, and 78000 ohms between contact and output (is that bad? I don't know what it should be). Coil is getting the full 12V needed. Distributor cap looks clean and solid. Points have been replaced by a Pertronix Igniter module. I'm researching how to test this. Any advice is appreciated. Also, if I decide to replace the coil and/or igniter, does anyone have suggestions? Thanks again.
