Milt K from Pa
Hi Barners,
My recent purchase of a '57 Bird has a missing part. The car has an original trunk-mount "Ford" antenna. The connecting cable that plugs into the the antenna has a missing end. I believe it should be about 1/2 inch in diameter,and will "snap" in place. The replacement antennas use a screw-in type connector. I am interested in acquiring this end connector so that I can install it on my existing coax antenna feed wire. Any one out there have access to this part???
Thanks,
Milt K from PA
Thanks,
Milt K from PA
