Hivolt5.0
I'm having some fuel delivery problems with my '57 Ranchero. I knew there was some rust/dirt in the tank because I could see remnants of it in my fuel filter (installed before the fuel pump). I assumed the tanks was probably really rusty/nasty inside so I dropped the tank this weekend. While draining it, once the fuel level dropped, the fuel stream coming out of the tank pickup just stopped but there was still a good 4 gallons of gas in the tank. (I know this because I dropped the tank only to realize it wasn't empty and I poured the remaing fuel into my gas can.) What surprised me when I looked inside the tank was actually how clean it was in there. Very little rust but there is definitely dirt in it. I'm assuming the pickup sock is clogged but how do I clean it??? The holes in the tank where the filler neck and the sending unit go are too small to reach my hand into the tank.
thanks in advance for the advice,
David
David
