57 Ford with 312
How much is "some"? If you're still running the road draft crankcase ventilation system you will get some fumes out of the breather at idle and low speeds. Converting to a more modern PCV system will pretty much eliminate that. If it's in the mosquito fogging category you have an internal engine problem. Rings?
