10gaugemag
Not sure if mine is correct or if somewhere down the line the heat control was deleted.
I do have 3 holes on inner fender, passenger side where I believe there should be an adjusting valve with a cable that goes inside unless mine was so basic it is wide open when you're running heat/defrost.
Any information or advice would be greatly appreciated.
I found this image on the net and believe this is what I am missing if something is indeed missing.
