I have a 57 312 Y block in a 58 F-100 that has a backfiring issue. Once the engine is warmed up it will backfire every 10-20 seconds, some are louder than others. I attributed that to too rich of fuel, so I adjusted the jet ports on the Holley 4 BBL carb, it did not help. I've used my vaccum gauge to adjust the jets to maximize the vaccum, but I can screw the jets in and out as much as I want and it does not affect the vaccum. I've even replaced the carb (thinking maybe I have a warped fuel block) and the problem still exists with the new card. Am I wrong in thinking too much fuel? Can you help me confirm my carb is on correct?
Any help would be appreciated.
