Grumpy Rick
I have a '56 Victoria 2 Dr Hardtop. The drivers door often will not latch when shut. After a couple tries, I have to fiddle with the toothed wheel on the door, and if I get it right it shuts fine. If not, it just bangs against the catch.
It does this about half the time I shut the door. I assume there may be a spring in the latch that is supposed to return the wheel to the proper place??
Is this something I can fix, or do I have to get a new/rebuilt latch? If so, are the old rebuilt ones better than the new repops?
I am hoping there is a fix for mine.
Rick
PS: It is a Sunset Coral/White Vickie, frame off back in '91, with an '86 Merc EFI 302, AOD, disc brakes, Posi, 4:10's etc.
Rick
