56 T-Bird Spark Control Valve (SCV)
Hotrodgss1
New member
Does anyone know the OEM Holley SCV part number for the teapot carb on a 312?
I found a couple on eBay but I need correct part # to ensure it's the right one for my car
It's a #s matching show car so ditching the load-o-matic carb & distributor are not an option.
The actual number on an OEM carb started with an ECJ
ECJ-9510-Y 312 Automatic List 1164-2
ECJ-9510-Z - 292 Standard List 1163-2
This is from the Restoration manual. Oddly enough, it does not give the suffix for the 312 with standard trans.
ECZ prefixes were sedans, although some people dispute this..
I don't have the Ford part #, but Oldmics gave you the correct Holley number. According to my Holley manual, it's the same part number spark valve that was used on any teapot on '56 Fords, 292 or 312. I don't think it would downgrade any judging of your car to use a reproduction one out of a rebuild kit either.
Sal
Any old original Holley spark valve will also be stamped "65" on the side of the hex. (also the suffix of the Holley number).
Sal
