R rodomotive Member Sep 9, 2014 #1 I would like to know the correct/original routing and grounding location of the ground cable coming from the battery on a 56 T-Bird. Last edited: Sep 9, 2014
paul2748 Well-known member Sep 9, 2014 #2 The other end of the battery ground cable is attached to the bolt that holds the spark plug wire holder to the block on a 56. 55's and 57's are different.
