You guys gave me good advice last year when working on an issue with my brakes. Finally getting back to this and have another question. Original issue was brakes hanging up and I was trying to determine if it was a bad booster (stock Midland) or perhaps pedal pressure on MC. When i removed old MC, (top could NOT be removed), I found little fluid inside, so I know it had been very low on fluid. I replaced the MC (bench bled) and decided to see how the brakes were before messing with booster. Seems easier to diagnose one variable at a time. Anyhow, I then started to bleed the system starting at the booster. When bleeding the booster, I could not get anything more than a few drops of fluid (ugly fluid). Just air. Is this indicating some kind of leak/bad seal in the booster? Appreciate any guidance.
greg
greg
