Both point down at a slight angle toward the front when in neutral. If the linkage is hooked up and adjusted properly neutral at the shift lever on the column should equal neutral at the trans. Have you tried to move the car with the lever in neutral? You could raise the rear wheels off the floor, disconnect the linkage at the trans and try rotating the rear wheels. If they won't rotate move the levers at the trans until you find neutral.
