56 sedan delivery rear window gasket
56sedandelivery
getting to the point of putting in the glass. It list the rear door glass as being pre 6/1/56 and post 6/1/56. My car is 10/56 so no problem there. Problem is I am not sure if the door is what came with it since way too many things odd about it. Mainly the license plate holder is not from a 56 and the window pinch weld was 1/4 off in the lower center. What would be the differences between the the pre and post 6/1/56 doors? Thanks
Update. Would the difference be with or without a trim groove? I do not plan o using the trim around the window (do not have it). So then that is there any difference?
