Has anyone found a vender for replacement cat whiskers/felt for the upper quarter window? This is the part that the window slides up into fixed to the roof line. Also if there is a video for doing the repair? Thanks Tom
Ranger9903 - if you find something that works, would appreciate your posting.
I just replaced the lower "fuzzies", but like yourself have not found replacements
for the upper on the quarter window. And, of course, 55 and 56 take the same
parts.
restoration specialties said they have the right fuzzies for the car. You need to trim them to fit and remove the bottom edge to show the little tabs then they slide right in. I tried this and when removing the bottom edge you have to be very carful cuz the tab will break off. I did one side and i am please with the way it looks. just take your time and it will turn out great. 98 in piece for about $25.
