I recently rewired my '56 Country Sedan with a 3 speed manual with O/D. The loom did not include a wiring circuit for the O/D so I didn't touch it. It had been working well although the kickdown feature did not function. While I was out driving last week, the O/D kicked out. The fuse on the relay was blown so I took a look at it's wiring. Pretty sketchy. I dug out my '55 Ford Shop Manual and replaced most of the old wiring. But I still have one wire that I don't know where it is suppose to go. It's the white wire from the "D" contact on the kickdown switch. On the shop manual, it shows the white wire running to what I believe is another relay. The manual doesn't call it out but it does indicate that it has two coils and a pair of points with power drawn from the ignition switch circuit. I don't know what that part is or what it looks like. Hope someone can help.
