wi0v
My 312 has a Carter Carb and the double vacuum advance. I removed the distributor six years ago. Now need help on routing the vacuum lines. One goes from the distributor to the manifold port below the carburetor, to either the top or bottom port on the distributor? The other vacuum line, I have (unfortunately) no idea. I sure could use some help! I have some Tbirds used the same system, but I am not sure.
