'56 Mainline Throttle linkage
JSRTUDOR
Hi everyone, I am planning to swap out my 223 with a 272. It has a 3 on the tree. I noticed the linkage is on the driver side of the one barrel on the 223, and on the passenger side of the two barrel on the 272. Does this mean I am going to need a different throttle cable and linkage? Also, will a four barrel intake from a 292/312 fit a 272? Thanks!
What throttle cable do you have now? I believe original may have been a rod & lever arm mounted to the firewall???
The manual transmission throttle linkage is much simpler than the automatic version.
... will a four barrel intake from a 292/312 fit a 272? Thanks!
Yes but... the 4bbl carb, intake manif and distributor were changed by Ford each year in '55, '56, '57+... maybe even the throttle linkage and air cleaners too.
The 4bbl setups from '55, '56 & '57+ should be installed as a year matched set, not mix & match. The carb vacuum pressure & plumbing to the distributor isn't the same until '57 and newer.
The '57+ versions are generally preferred due to the 'new' mechanical timing advance design of the distributors and more modern style (not teapot) carburetors with the larger bolt pattern.
You might want to hang out here to see pictures of the installed linkage and parts sources. https://www.facebook.com/groups/fordyblock Your 272 like the 239 used the Load-O-Matic carburetor & distributor combo,with later 4 barrels they do not have the proper vacuum for your earlier distributor. Usually when swapping to a 4 barrell most will also swap to '57 and later distributor. ;)
From what I remember from converting my two bbl 54 to a 4bbl, the part that attaches to the firewall is the same. The difference is a piece that attaches to the back of the intake that crosses the intake to the right (passenger) side.
Now both were V8's so I don't know if there is a difference in the piece of linkage that bolts to the firewall for a 6 cyl. If someone has a 54-56 two bbl car I hope they wouldl post a pic.
The intakes will swap with no problems. There may be some port mismatch if your using 55/56 heads with a 57 intake, but it should work ok. If your using the 55/56 intake, no problem
If everything goes right, below is a pic if the 54 linkage (2BBL). It's for an automatic, but the only difference should be the kickdown rod for the automatic Notice the piece at the top with two holes in it - this is the piece that bolts to the back if the intake
in the picture paul posted I have marked the automatic transmission rod in red and the carb linkage in green to help you hopefully.as darrel stated the bracket by the spring is for automatics
Did I not send you the entire complete original throttle linkage for a '55/56 272 (for use with 2-bbl carb)? Using everything that I sent you, there is no need for additional cable. There originally was no cable, all mechanical. I believe the only thing you nee3ed to get was the idle return spring.
Did I not also say that this was for 2 BBL (Holley 2100 or Ford EBU) carb?
The stuff I sent you will not work for Holley 4-bbl teapot or anything else without modifications.
If you have a cable now and are going to use a 272 with 2-bbl ('54/55 or '56), just use all the stuff I sent you and get a idle return spring. You have EVERYTHING needed from accelerator pedal to carburator. Throw that aftermarket cable in the trash.
The intake will fit on a 272, but the throttle linkage for the Holley Teapot is COMPLETELY different from that used on the 2-bbl intake manifold.
In other words, If you have now decided to put a 4-bbl intake on the 272, you might as well throw out all that stuff I sent you.
Dave, I thought you sent that throttle linkage to Steve Fritz for his '55 Ranch Wagon in Wisconsin ? He bought the car from me last year, and I thought he told me that ?
Sal
Dave, I thought you sent that throttle linkage to Steve Fritz for his '55 Ranch Wagon in Wisconsin ? He bought the car from me last year, and I thought he told me that ?Sal
Ooops, was it Steve I sold that stuff to??? I've sent him a few things lately. I got confused. Sorry!
And, I don't have another 272 throttle linkage assembly left to sell either.
I would like to ad some pictures but this site won’t let me. Keeps asking for a url
You have to use the "Advanced" reply window not the "Quick" reply. To attach photos there's a Paperclip button at the top of the text box that opens a pop-up Manage Attachments box to browse to the photo you want, then select and upload it.
The '55/56 V8 2-bbl has a small two-hole mounted stabilizer on the firewall for the throttle linkage.
The '55/56 I-block 6 has 3-hole mounted bellcrank that mounts on the firewall.
Heres a photo of the 6-cyl part. It is the silver thing mounted on the firewall.
Here's a photo of the parts needed to assemble the throttle linkage on a 55/56 272 with original style 2-bbl carb. Only thing not shown is connecting link and return spring.
