56 Ford power steering options
mikhett
Tried the search function.It wouldn't open.Im looking for options on the 56 Ford car . thanks and MERRY CHRISTMAS TO ALL BARNERS!
I have seen complete set-ups e--- for about $1700.00 that are ready to go. There is another set-up that is a true power steering and you use their steering box which is made by Borgeson. I think with this set-up you will be over $1,000.00 just in parts and I don,t think you can run a manual trans. with it. As far as using the Ford P/S 1954-56 works and the pump and pump bracket needs to be those years to line up with the pulley and clear the inner fender. I hope this helps.
I have seen complete set-ups e--- for about $1700.00 that are ready to go. There is another set-up that is a true power steering and you use their steering box which is made by Borgeson...
:eek:
...too much eggnog...
I thought the OP meant as new car option information...
Another option is a 76-80 Granada set up. The CVA has a write up on installing it on a 54-56 Ford. Very similar to a stock set up.
