Trying to get to the bottom of slop in the wife's 55 bird and after replacing all the rubber pieces I am in the midst of a freshen up on the steering gear and wanted to check the worm gear is OK...
If you check out the image you will see that the center tooth in the worm gear is a little lower/smaller than the outside two. Does this worm gear look OK from a wear and tear perspective?
