Grumpy Rick
When I bought the car it was 'restored' but the PS, Trans, and Motor sat for several years before being used much. I fixed the PS problems, except for a leak in the piston area. The trans has a big leak near the front seal, now that it is being driven.
So, I went to Auto Zone to get some magical stop leak stuff. I have read here that they work for a while and then later leak worse than ever. I met a man who said he owned a transmission shop for 40 years, so I asked him about that problem.
He said that the various poducts work by loosening up the seals, and expanding them to slow the leaks. The problem is that they keep expanding the seals until they leak more eventually. He said he only could recommend one brand...K&W TransX, for trans leaks. He said it works for a while to expand seals, then stops, unlike other brands. It will not over expand the seals. It is also NOT for PS leaks.
So I got some. Time alone will tell if he was right, but at least he had an informed opinion, and I didn't have to flip a coin to decide which one to try.
I will report results.
