Hi, Does anyone know the correct location of the overdrive relay for a 1955 Thunderbird. Also does the overdrive cable go on the left side of the steering wheel or the right side. Any help will be appreciated. 631-738-7712
Picture shows correct location of overdrive relay in relation to starter solenoid. If you look carefully in this area you will find two dimples in the firewall (if it has not been heavily painted over) where you will punch the mounting holes.
