dmsfrr
The brake pedal on this car wants to trap my right foot under it, more than a bit tricky to lift off of the gas pedal.
It's an automatic so after a couple bad moments I've been driving with my left foot for the brake.
It has power brakes and a good sized (3" x 5.5") *Swift Sure* brake pedal.
I could possibly use the smaller brake pedal for a manual trans car but I'm thinking this car may incorrectly have a brake pedal arm from a manual trans T-Bird, one that's closer to the gas pedal than the original 'automatic' part would have been, IF there are two versions of the pedal arm. ???
Assuming a part number is visible without removing the whole arm from under the dash,
is there one on it and what number should it be?
If there are two versions, is there an easier way to tell them apart?
