fast fredy
Hi guys . Is there anyway to check operation of the kickdown switch , car is not on the road yet but I want to check the switch before installing carpet . I put a test light on the coil wire and pushed the switch thinking that it would momentarily cut the light but it did not . I dont know if the car has to be at certain speed to be able to do this .. If I ground the governor I here the relay click . Maybe if I check the test light with the governor grounded , that test might work . What do you think . I'm try not to have to take out the kickdown switch as it looks like a pain.......Thanks Fred
