55 neutral safety switch
Ford coupe
Ok i got and installed a new neutral safety switch on my vicky but now how do i adjust it..It will start in reverse now so where now?? There is a bit of adjustment via the slotted hole in the switch so will i get enough there or it looks like i could loosen the mounting bracket on the steering column and maybe turn it a bit..sO IF ANYONE CAN HELP MUCH appreciated..bY THE WAY CANNOT FIND ANY INFO IN THE 55 SHOP MANUAL..gOTTA GET THIS DONE AS ITS DRIVE TIME...tHANK YOU IN ADVANCE..
"There is a bit of adjustment via the slotted hole in the switch so will i get enough there or it looks like i could loosen the mounting bracket on the steering column and maybe turn it a bit.."
The answer is yes.
The bracket bolted to the base of the steering column has two dogs that fit into slots at the top half of the lower steering tube, so that part is stationary. The neutral switch itself has slotted mounting holes for adjustment purposes.
Place gear select lever in neutral (with parking brake on). Loosen the two 5/16 hex head screws that hold the neutral switch to that bracket. Now move the bracket around until you hear a little click inside that switch. At that point, you will notice the actuator on the switch is aimed upward and a little bit to the left. Hold it firmly there and tighten the two screws. Now it should start in neutral.
